Hi All,
Have a 94 mercruiser 350 tournament ski that will not get up to temperature. New to me boat that I picked up last fall. Opened up the thermostat housing last night thinking it was stuck open and found a lot of rust flakes in the reservoir. Removed all the debris and replaced the thermostat. Same issue. Temp gauge doesn’t bounce off the bottom until I restrict the water flow. I didn’t see a sleeve in the thermostat housing could that be the problem?
