Welcome Guest - Sign Up today
No announcement yet.
updated shift plate 864363a1 wiring
  • updated shift plate 864363a1 wiring
    Can I get wiring instructions for the above shift plate for a pertronix electronic distributor
    Ayuh,..... one wire to ground, the other wire to the coil's (-) terminal,.......
    • #3
      Bondo, that switch might be the normally closed one instead of the normally open one
      Check with a meter . if you see continuity at rest and no continuity when depressed you need to wire it in series with the coil`s + wire to interupt the 12v side
      NO PERSONAL QUESTIONS, THIS IS WHAT THE FORUM IS FOR.
