removing lwr unit on alpha 1 gen 2
grilljc
Trying to remove lower unit. Have removed all six bolts. Per the manual I just need to tap with mallet and a wood block. I have beat it severely and it does not move. What am I missing? Has only been in fresh water with corrosion at all around the joint.
Bt Doctur
Define what bolts you removed 2 on each side, 1 in the front, 1 UNDER the trim tab
QBhoy
Yeah. Have you remembered the often forgotten one under the trim anode ?
ThomW
Like the Doctor said, there should be two on each side, one in front, and a last one under the anode at rear.
You also removed or disconnected the trim arms from lower unit too...right??
havoc_squad
Trim rams go on the upper, no need to disconnect from outdrive if only removing lower unit.
+1 to the hidden bolt, likely where the anode is above the prop shaft and in the back.
Also, last time I remember the drive needs to be on forward for removing lower unit.
Might I suggest getting OEM service manual or head over to boatinfo.no and check it or post before applying brute force on something.
Bt Doctur
Only in fwd to remove a Alpha drive , only in neutral to remove a Bravo drive. Lower can be dropped in any gear
ThomW
Yup. My mistake. No need to remove Rams for the lower unit drop.
