Went out Sunday boat ran fine about 3000 rpm then all of a sudden motor raced to over 4000 and started to slow down I obviously backed off and realized I was no longer in gear turned it off but not much to see so got towed in and when I got it home I went to flush it and it would not suck the water through the earmuffs pulled the out drive off separated the lower impeller was fine shift cable seems to be ok but what I did notice the prop is supposed to lock when in forward gear I can still turn it any help would be greatly appreciated
