you can, it will cost you a fortune, however you can. you will also need to change the cam, as the carb cam and MPI cam have different LSA and ICL's
would be cheaper to sell boat, buy boat with MPI
that begs the question, what do you think you will gain with MPI over a carb? it wont be fuel economy as both will get the same. it wont be power output as that will remain unchanged. the only thing that MPI gets you that you notice other ant better tail pipe emissions is resistance to barometric pressure changes and a slightly smoother idle when the motor is cold.
