I picked up 2001 searay 180 today as a project for my son and I over his winter break. I putts around with small Johnson outboards I’ve never fooled with a mercruiser. From what I have read here if maintained the 3.0 is a good motor. So I’m hoping the issue is nothing major.
The story I got from the original owner was they took it out for a ride in about and about 15 minutes into the ride we start losing power. They were able to slow motor back to the trailer. The guy saw milky oil on the dipstick and parked it.
It’s a Central Florida boat so it mainly saw freshwater and brackish water. I’m hoping it is not a freeze issue being we hardly ever get a hard freeze here.
Ive checked the compression and it’s in the 150s across the board. Doing my initial checks I found the drain line for the exhaust appear to be off. I’m not sure if this could be a cause or if the previous owner disconnected it from there instead of up at the top?
Any suggestions on where I should start looking first?
Thanks in advance for any advice.
