whiskeyRichard
- Sep 16, 2018
- 96
I am looking to get a bit more grunt from my boat. I'd like to see 50MPH.
Right now, with a 15p Al prop, she has a ton of snap and tapers after 4k RPM and tops out about 43mph, but runs right where she should at WOT. I tried a 17p prop and still has decent snap, but runs about 200RPM shy of where it should be at WOT.....I did not check the speed but seemed a little faster than the 15p.
I have attached a picture of the boat. It has a hull that when it was built, was designed for performance and the boat is not too heavy.
I figure I need heads, intake, carb, cam and maybe exhaust.
I have a closed cooling system. The exhaust is early cast iron kodiak exhaust manifolds and risers and it goes through the y-pipe. I do run an exhaust tube instead of an exhaust bellows.
The motor is a 1980 Mercruiser 260 and has been rebuilt with about 200 hours on it now. I recently checked the compression and all cylinders were about 140+/-.
I don't mind pulling the motor to do the work as I was thinking about detailing the engine compartment and bilge area anyways.
I have read on here a few other people looking to do the same thing, but need a little more guidance regarding particular parts.
I was planning on getting an edelbrock carb and intake. Would the 1409 600 CFM be enough carb? Any advice regarding heads, head gaskets and cam would be great as well.
Thanks
Thanks
