bfeils
- Aug 1, 2018
- 25
Hi everybody. I bought a non running sea ray 185 in the middle of the summer and partially rebuilt the motor due to two stuck piston rings. I replaced the crank and lower end bearings as well as the pistons and rings. No machining done because it was in good shape with low hours. Anyways, it runs really good but I'm not getting as much rpm as I should be. With the stock 14.25x19 prop I can only get 4200rpm when most people with this boat are able to get 4700-4800. I've gone through almost the entire Low rpm checklist including weighing the boat to check for water logged foam. The only thing I haven't checked is fuel pressure and it's not easy to check on this motor but I'm going to get to it. Anyways, I opened the carb up after running it and the fuel level in the bowl seems low to me. Even though the float levels have been checked and rechecked by both myself and a fuel system specialist shop. Can low fuel pressure leave the fuel level low even with properly setup float? And, can low fuel level in the carb cause a lack of rpm at full throttle?
