Mercruiser alpha 1 gen 2 I/O
SeaRay 2010 17 ft.
1. My trim is stuck in up position. The pump seems to work and I don't hear any clicking from the solenoid. I checked the reservoir and it looks kinda pale but not milky white. The fuses appear good. Could the oil be the problem? The wires on the trim limit and sender appear ok. Any suggestions?
2. I recently changed the gear lube and the impeller on the lower unit. When I refilled the gear lube, I started from the bottom fill hole until I saw lube coming out the vent hole. I replaced the vent and fill screws and filled the gear lube monitor/reservoir. Now whenever I turn on the ignition key, I hear a loud 5 sec alarm then a shorter 2 second alarm every 2-3 min when the engine is running. What could be the problem?
SeaRay 2010 17 ft.
