The boat in the title followed me home a couple of weeks ago and the add said it had overheated & he told the kids that if it started to cost him, the boat goes.
I should have asked more questions.
He said it wasn't run long after he saw that it was overheating, but I doubt this. the impeller had no vanes and I found them when I removed the water inlet water picks (that's what they're called in the parts diagram), which keep chunks from entering with the raw water. The water tube had melted and sagged over the rear bolt that holds the upper and lower water pump housings together and in the bearing carrier, I found more rubber, including what looks like shutters for the exhaust and water in the exhaust.
How much of a PITA is it to get to this?
Thanks
Thanks
