I have a 2016 MerCruiser with a Bravo 3 leg all fitted new in 2016 to a 28ft Aluminium mono hull vessel. It is serviced every 100 hours by MerCruiser dealer. Since the MerCruiser was fitted the sterndive oil has been burnt black with the smell of burning. Just prior to the service about 80 hours the forward gears do not engage for up to 5 seconds. This was reported to the dealer. They change the oil and fix the gear/clutch problem.
After many services and the same problems they fitted a spray unit to the leg, but this "we fit them to all stern drives" cavitated so badly the vessel could not get to 10 knots. They removed that one and told me Mercury are designing a new spray unit. Another 100 hours to make it 400 they change the burnt oil, fix the cone clutch and fit the spray unit. At 450 hours I am travelling for 1 hour at 2800 revs at 19 knots and a very loud noise happens in the stern. I get it back to the mechanics and they discover the top box gears have broken {split} with signs of pieces of gear, bits of the case hardening chiped away and wear on the gears.
My question is this: I have read about the high temperatures the sterndrives can get to, 280 F so having the oil running at that temperature and then coolling down countless times for nearly 500 hours will this do damage to the top box, gears and bearings.
