silver_power
- Jul 8, 2009
- 314
Hello, i have a small problem (again) with my engine 350Mag Mpi (1A348183). It starts perfect at the first time of the day but every other time it crank for 1-2 second more than normal, idles for about 2sec at about 250rpm and then it idles at 550rpm steady and perfect. For example, yesterday, i started the engine for the first time , started perfect, and turned it off at about 30secs.If i start it again immediately, it will start perfect agian. But if i try to start it at more that 5mins (10mins, 30mins, 3hours 5hours etc)it will start again with low idle for about 2secs and then perfect again. It is totally tuned up and runs perfect. Yesterday i made a test...after i turned the engine off, i let the throttle at wot for about half an hour (in case of flooded engine) and started after the engine. It crancked normally for 2secs as usual and it fired it up. Offcourse i pull back the throttle and the engine idled perfect again. I think that the fuel injectors leak and flood the engine while it is stopped, but first i have to say that during idle there is no smell of gas and second i do not have higher fuel consumption than i used to have. At the start of this summer season, as i had some other performance issues, i had checked fuel pressure and it kept about 40psi for at least 2mins which means no leaks and also i checked the injectors to a professional and cleaned as well and he told me that they were in very good condition..........I had not had the fuel pressure gauge yesterday to check it again, only the diacom which confirmed that i had no active faults, but is it possible to have this symptom caused by a leaky injector? Shouldn't i have any more symptoms? Next time i will go to boat i will have the pressure gauge to check but is there anything else i can check?
