Oshkosh1
Ensign
- Jun 8, 2009
- 968
Hi all...
When I bought my boat, it had set for a few years. Although in almost perfect condition for it's age(including only 400hrs and still the OEM plugs/cap/rotor etc...) I've run into a few age related corrosion issues. One being the trim. Last year I did get the trim working pretty well including calibrating the gauge...but now it will not raise. At first, it started intermittently then I had to use the "Trailer" button(both handle mounted) to get it to raise up underway because the "UP" button didn't work(just clicked). NOW, although it does "click"...even the trailer feature won't do it. Going down is no problem and the motor works great headed that way. Sooooooooo...I just removed the whole pump/solenoids in the hope that I just have a bunch of bad connections...which wouldn't surprise me.
When I get it all cleaned up and ready to install...do I need to bleed the hydro's at all? I tried to limit the amount of oil loss out of the individual lines but obviously there was some.
Searched but couldn't find anything specifically regarding any bleeding necessary...
Thanks again!
Thanks again!
