I have a 1995 3.0lx that had been great for many years. It sat all winter as normal with heat lamp in engine compartment as I always do. We rarely see Temps below 20* here in Virginia Beach. Went to drain oil and saw this mess in my oil. I have since flushed the motor 3 times with diesel running a minute each time. It's clearer now.
What's the common water intrusion point? How can I find it? Should I fill it with oil and see if it happens again? Seems to run fine. There was a suggestion from a friend that it might be bad intake gasket? Does that even seal water from oil?
Lost. Thanks
Lost. Thanks
