cableguy1979
- Jun 25, 2017
- 121
Ok so I bought a 1996 crownline with a 454 mag from a friend. I know the boat but I don't know what's wrong. First the boat was left open to the weather and the boat filled with rain water. It got in the fuel tank and after it was drain it was attempted to start. There was enough water in the boat to be up to the engine. The engine had water in the oil which I assume came in from the intake and past the rings, water in the fuel rail and water in the outdrive from sitting filled up so long. Guy swears it ran great no problems until it filled up. I rebuilt the VST and purged as much of the water out of the fuel system as possible with compressed air while having the shrader valve open and pressurizing the fuel system and turning over the motor. New filters, new oil and new plugs. Boat fires up and runs but idles around 1200 to 1500 depending. When I first start it it runs around 1200 but after I rev it it idles around 1500 and wont settle down back to 1200. I let it run for about 15 minutes twice. I pulled all the plugs and number #8 has water on it. I start the boat with the plug out and let it expel any water twice but still get water on the plug. I dont know if there is more water in the fuel rail but I think one cylinder with water on it is doubtful especially after 15 minutes of runtime. So i feel i need to start looking for a busted head gasket or can a exhaust riser gasket cause this? If i do a leak down test how could i tell? Seems to me if its the head gasket it will leak down no matter what. If the exhaust riser can let water in then should not leak down on compression stroke but when the exhaust valve is open it will let water in? I still don't see water in the oil as of yet but the condensation on the plug doesnt say there is enough water from that cylinder to have any milky oil yet.
Any clue what is causing the engine to idle so high? I hear a ticking lifter but not a cause for high idle. TPS, idle air? What do I test first?
Any help is greatly appreciated
