kulle
- May 23, 2018
- 294
Still trying to track down why my boat runs for a few mins then shuts off. I have spare at coil and from distributor when it shuts off. Thinking of checking oil pressure switch and if i can get it running, voltage at fuel pump. I had a small amount of oil on the underside of the oil switch...was thinking about pulling it off to test, does anyone know if I remove that switch, will oil drain out completely or is it high enough on engine block that it wont? Mercrusier 4.3 L V6 ( 1993)
