Howdy, all. Long time reader; first-time poster. I hate to ask what is probably two unrelated questions in a single post, but here goes:
I got my hands on a steal of a deal on a 2003 Monterey 268 SC with a Mercruiser 350 MPI and Bravo III out-drive about a year ago. Ran fine for the first six months, then overheated on the water hose one day in the yard. Decided it could probably use a good tune up and seasonal prep from a pro, so I took it down to the local marina repair shop. The guy called me back and told me he'd like to replace the impeller, thermostat, and manifolds and risers for good measure--all to the tune of about $5k. I figured, "Hey, I'm a mechanically inclined kind of guy, and YouTube is my faithful guide in all things," so I decided I'd do it myself. Needed to learn my boat anyway, and that sounded like a great start.
Long story short, I whipped out the manual and started learning all I could. After about a month of reading this forum and watching videos, I ultimately bought a bunch of parts and replaced the following: Starter, manifolds, spacers, risers, spark plugs, wires, coil wire, distributor and rotor, impeller, thermostat, and fuel filter. I used all new gaskets for everything like all the pros suggested, and gave her an oil change and new filter there, as well. I removed and back-flushed all of the raw water cooling system hoses that I could access from the front and sides of the engine (not a ton of room to work with or even see in the back area) and got some corrosion flakes, but not enough to scare me. I even rewired a bilge pump under the cuddy cabin that was acting up.
When I had her all back together, I stood back in awe of my latent mechanical prowess and gave a little nod to all the guys who posted videos and forum answers. Thanks to all.
I turned the dial to wake the batteries back up, and that pesky bilge fired right up and cleared the cutty cabin hull space. I was well on my way to posting my own helpful answers one day; I just knew it. I put the key in, ran the blower for a minute, and read the gauges--five by five, all looking great.
Then I turned the engine over...starter doing its job great, but no fire. Scratched my head for a while, gave it a few connection checks, and tried again. No fire. Hit the forums. Troubleshooting. Troubleshooting. Downloads. Reading...Finally found a guy who was talking about faulty IAC modules, and he suggested giving it some extra throttle with the prop bypassed, so I tried that. It fired up. Maybe need to replace that IAC unit. I put it on the list, but now its running, so I pull her back to idle. Runs good, sounds great. Water coming out of the stern like you'd expect, a little coming through the side exhaust; I'm not sure how much to really expect, so I assume that might be normal until the thermostat opens up. We'll see.
About five minutes go by... heat rising. I see it climbing up to just over 150 F, so I'm expecting that brand new 160 F thermostat to kick in and knock it back down any second now. Except it doesn't. Gauge hits 175 F, and I freak out and shut her down. Time to do some more reading. I'm all over the web, but no spot on advice.
I flush the hoses again, pull that thermostat, clean up what I can, and put it all back together. Put her on the hose and try to crank again. No fire. Try the increased throttle. Doesn't work this time. Scratch head. Check connections. Pull the coil wire and reinstall. Hmm... I remember a video where a guy was talking about engine breathing, so I pull the air intake and find that little muffler filter on top. It's filthy. I know they're like three bucks, but I just clean it up with Dial Ultra and rinse the heck out of it and dry it completely and put it back in. Back to the console, give it some throttle.
It cranks again! We're in business. Overheating issue happens again! I shut her down at 175 F.
Points I haven't brought up yet: I saw a few posts about distributor caps saying to make sure that some little black wire is put back in place; no good details, though. I have some little black wire that is loose, but I have no idea where it should go and I didn't see it come off in any of the repairs. It sits on the left side of the engine as I'm facing the belts. It's long and is secured on the floor of the hull with about two and half feet of wire. Also, I've seen videos where a sensor wire with a plastic housing end is fitted into the back of the distributor cap area, but I can't find a wire set that would fit there. I don't remember removing one in the replacement, either. Does it have to have something plugged into it, or is that just for running diagnostics? Finally, the left riser (and the water coming out of the left exhaust elbow gets hotter than the right riser and the water coming from that exhaust. Maybe a blockage there?
I'm really stumped here, guys. New pretty much everything having to do with ignition and temperature control, yet both problems are persisting through all of the repairs.
What could be causing my ignition issues, but would seem to cause no problem once I've got it cranked?
What is the most likely reason that I'm still having overheating issues?
Anything helps. Thanks so much for all the reading.
J
J
