MJTurner42
- Sep 13, 2017
- 22
I have a 3.0 Mercruiser 2002 with an Alpha 1 Gen 2 Outdrive. Took the boat out to the river this weekend and heard a knocking sound coming from somewhere in the engine compartment when ever I brought the boat over no wake speed. When in idle, revving in idle, or at no wake speed the knocking sound was not present. Anything over no wake speed there was a loud knocking sound that was clearly metal knocking on metal.
I know two times ago one of my buddies who borrowed the boat hit a dead head in the river and damaged the prop beyond repair and took the entire skeg off the outdrive. (I know poor choices in letting someone borrow the boat). The prop was replaced and a new skeg installed. The boat has been fine on two outings since then.
The previous time I took the boat out I was running on an inter-coastal waterway and had to run the out drive in 1/4 to 1/2 trim, above where it should be run at. I didn't have a choice because the tide was out and I was destroying the prop.
Anyway I now have this metal knocking sound and don't know what it is. I listened to the valve cover with a screwdriver and it was not coming from there. I am convinced it is not an engine issue because it only happens when the drive is in gear and at above no wake speed. I think its a drive issue.
Any help would be appreciated with this!
Here is a link to a clip I took of the noise: https://youtu.be/1skXiJEJdNo
