Have had this issue happen last 3 times out and would like some recommendations on approach to find root issue. Motor starts up and runs great... ride for a while to anchor spot or other dock.... .hang out for 1 or more hours... then issue pops up... when starting starter motor turns motor over... it will always have the initial "start"... plugs fire get momentary (about the length of the time the key is turn over) power .... key goes to on position and then one of 2 things happens... it will continue running very rough with voltage gauge jumping around or hovering around 12 v with barely any power or it just plain will not continue to run at all.... in all cases so far waiting for some more time after attempting to start it "comes back" voltage meter is steady at 13.8... starts and runs with no issues again to get me back. So far I replaced the connectors from the alternator as the + one was corroded (1st trip where I thought that was issue) and looked like it could be intermittently connecting.. I replaced the alternator as the old one was pushing out 14.9 v and figured the voltage regulator was near its end. (2nd trip where I tested) I still have the issue after these 2 changes. Some other thoughts... when it does not start after riding somewhere and sitting for a while I have the engine cover open and it is possibly cooling some portion of the electrical system that once it gets back down to some temp it works... wiggling the harness on the engine and wiring to the switch don't seem to change the predicament. Given that it runs well until it doesn't it seems like a may need to replace some or all of the wires involved in supplying current to the ignition.... I am hoping one of you has seen something like this and could point me to better diagnostics or ideas on where to start to trace this down.
