1lastweekend
- Nov 7, 2015
- 52
Hi I am working on installing a Pertronix 40611 3.0 ohm epoxy coil for my 1981 Mercruiser 2.5L engine, s/n 5907433. From what I have read on various forums, my OEM coil was a 1.5 ohm, but there's a simple wire swap to allow the Pertronix to function correctly. I disconnected the purple/yellow wire at the ignition switched terminal of the starter solenoid and also at the + terminal of the coil, tied it back and replaced it with a std 12ga wire at the same connection points.
According to the Pertronix instructions, where i was getting approx 6.5V at the coil with the points closed before, i should now be getting a full 12v (with the ignition keyswitch on) But I am still getting 6.5 volts!?!?! Not sure what I am doing wrong or if there is another trick- is there an internal resistor in the red wire from the harness to the + side of the coil?
OEM setup was red and purple/yellow wire to + side of coil, and grey and brown wires to - side of coil. Any help is much appreciated!
