Ive had a slight oil leak coming from my 3.0 liter since I bought it 7 years ago. The engine is very clean but without fail I always have a little bit of oil show up. I wipe it down and then its there the next time I check. Sometimes I think its coming from the top of the valve cover from the breather elbow and dripping down from there. I most commonly see it on the starboard side around and on top of the fuel pump. Its never much, always just a little but I find it obnoxious that I cant trace where it is coming from.
I also noticed oil seeping from around the manifold plug on the Port side. The Bolt that goes into the block is in tight, I have a hard time believe its leaking from there. However, it is at the very bottom of the engine so I'm curious if oil can be leaking/seeping from that same breather valve and slowly dripping down the port side as well. Please let me know if I'm missing something obvious.
