Hey guys, newbie to the forum from North Carolina. Looking for some help with a boat I am looking to buy. This boat is several hours away from me, but appears to be in very good condition for its age. We are really wanting a v drive is the only reason I’m considering traveling so far (8 hours) for the right boat.
Anyways, the seller has had this boat for 6 years. He has done regular oil changes to it but says he’s never had to do anything else to it. He also isn’t sure which engine it has. Admittedly he doesn’t know much about engines and isn’t very mechanically inclined. So, I had him send me a picture of the engine hoping I could find some details. The boat is a 98 model and has 300ish hours. This is the original engine as far as we know. He thinks it is a 5.7 mercruiser, I assume it’s a carb motor. I’d just like to confirm that that is correct.
Also, I’ve been reading that the risers and manifolds are bad to rust and leak water into the engine. I’m curious if the rusty spots you see on each valve cover are indications of the risers going south?
If there is anything else you guys can tell me from the picture about the engine or anything that looks like it’s worn out please let me know.
Thanks
Thanks
