Agree with Bondo, I never thought to compare a side pick of the gimbal housing. A rear picture (or the serial number), or a shot of the leg, and slam dunk easy. Most obvious differences being the shift shaft in the bottom of the bellhousing or the hydraulic ram hole location on the leg. Mercruiser came out with the Gen2 in 1992. I can see a boat manufacturer using 1991 components.
Another major difference, only the Gen2 has a speedometer tube connection at the intermediate shift shaft from the lower into a small hose that passes through the upper. I do not see that hose hanging in the photo.
ALso, Gen2, if I am not mistaken, never had the bottom bolts with the screw on anode. They were all aluminum carriage bolts.. that pic has the anode on it.
One note, if you find a complete Alpha1 unit, transom to outdrive, you can swap all of it onto your boat. Did your outdrive sustain any damage?
