Hello All,
So after about 1 year of sitting, I went to start the boat. The engine runs fine starts, idles etc. However after about 5-10 minutes of running, I noticed more then usual smoke. Therefore I Shut off the engine and have been waiting for it to cool down. I removed both the Engine Block Drain plug and The Exhaust Manifold plug and noticed no water was coming out of those. They were bone dry. I was originally using a garden hose connected to "water muffs" that I have always used and worked. The water is coming out the muffs without any issue
So I am trying to troubleshoot the issue now and isolate if it is a circulation issue within the engine or if it is the water pump in the outboard. Therefore my question is: Is there a way to bypass the outboard water pump and directly connect a garden hose to "some" hose on the engine to see if water will actually circulate when I try to start the engine again?
