Greg O.
- Jan 9, 2011
- 125
This Evinrude 7.5 was not making full power. I took it apart to re-seal the gear case. I found the shock absorber assembly binding with the water pump-bearing casting. The propeller turns very hard unless I back off the 4 screws securing the water pump casting. I do not see any problems with the shock assembly. There was a hardened washer on the bottom of the shock absorber that I do not see listed in the parts schematic. What am I missing? Thanks for any advice.
