Service Bulletin #1429 for evinrude
Status
Not open for further replies.
masterlance
My 70hp Evinrude(1976) Idles fine and if I can get it at top speed it does well, but throttleong mid way is when it boggs down like its starving for fuel. Have cleaned carbs replaced fuel lines and checked over fuel pump. I read about someone having info on this situation on a JOHNSON SERVICE BULLETIN #1429. Could anyone be of any help ?! THANKS for YOUR TIME
Joe Reeves
Re: Service Bulletin #1429 for evinrude
I may have that bulletin. Can't get at it right now (alarm set). Will check in the morning and get back to you.
masterlance
Thanks Joe . . I hope you do . . I hope to here back from you!
Joe Reeves
Masterlance... I have that bulletin, it's not #1429, it's #1144. Contact me via my e-mail address and I'll get it to you. Edit: no email addys
masterlance
Joe, i emailed you back. Hope to here back from ya. Thanks again for looking up the info
mobiletec
could i get that service bulitin also Iam having the same problem Thanks
ruprik
Probably too late for you but here it is for the next one. Johnson is 1429 (1st attachment below), Evinrude SB is 1144 (2nd, 3rd and 4th attachments below). They are identical in terms of instruction. I'm debating whether or not to do this on my 70hp 1976 Evinrude - there's no going back. If anyone has and has either + or - experience to report, please share.
For Google:
OMC SB1144
OMC SB 1144
OMC Service Bulletin 1144
Evinrude SB 1144
Evinrude SB1144
Evinrude Service Bulletin 1144
Johnson SB 1429
Johnson SB1429
Johnson Service Bulletin 1429
  • Johnson_SB_1429.pdf
Status
