I've got a new to me 1985 30hp that I was attempting to change the water pump on (very weak stream) and while fidling trying to get the keeper off the upper shift rod end the lower unit slid off the drive shaft. I was told on another site that now I may not be able to get the drive shaft to align with pinion gear in the lower unit/gear case.
With that said is it possible to re-insert the drive shaft and expect success with it aligning with the pinion possibly by rotating both the shaft and propellor? If so, how do you tell its aligned (I assume by rotating the drive shaft and watching for the prop to also rotate)? Should it click? How would you guys do it? I was thinking of painting the splines with die blue and then inserting it and seeing where or how the splines are meshing with the pinion, if I can even get them to mesh at all.
Is there a chance I can do this without tearing apart the gearcase?
Thanks in advance for you help.
