Muskiematt
- May 12, 2014
- 6
Hello, I have 1998 johnson 115 and I have a dead cylinder. After I took it out for a little ride I noticed it had little power under a load. When I got home I did a compression test and found that two cyclinders on one side of the v had 120psi and the other side had 100psi on top and 90psi on the bottom. The spark plug had no signs of firing on it and had some water on it when I removed it. So I think I have head gasket or water jacket gasket is leaking but I can't understand why it's not getting gas to make it fire. It def had strong spark to plug. Could it be not enough compression to open reed valve? Or maybe water is preventing the firing? I would think a little water wouldn't stop the firing process but I tell you the plug looked brand new with no oil or carbon on it. Any ideas? Thanks !
