Hello all I am new to the forum and have done my best to try and find answer before I posted but could not.
I have a 89 Evinrude 110hp have removed the vro pump about 1 year ago
lately the warning buzzer is going off I have verified oil tank line disconnected and not grounding
thought it might be impeller so I replaced that, water pressure guage has about 5 to 8 psi at idle
and about 20 -25 psi at 4000 rpm
the oil/overheat buzzer goes off, shut engine down wait 3 to 4 min cranks and runs fine,
next time left motor at fast idle about 2500 rpm felt the telltale and water was cool, after approx. 1 to 2 min the buzzer
stopped and motor seems fine as long as I run at around 3500 rpm or less does not overheat( I am guessing this is what is happening )
do I need to remove/replace thermostats ? does it need the thermostats ? or can someone point me in the right direction
thanks for any help
thanks for any help
