blugrasmaniac
- Apr 29, 2013
- 37
I am in a bit of a pickle. I just got a 1994 Evinrude V6 175HP two-stroke, and it was running fine until someone added gas, but no oil...
Predictably, the motor seized, and now I need a little help getting it repaired. I have a fair amount of mechanical experience - mostly on cars, but haven't replaced a piston before.
Just a few questions for now:
Keep in mind this engine ran great just prior to this - so I'm not looking to rebuild more than necessary as a result of any damage incurred.
Thanks for your time!!
- Only two pistons are seized; however, does this mean that they are "ok"? What about burning - should I be concerned about discoloration on the top of the piston?
- Assuming this engine has never been rebuilt, does the cylinder need to be bored out, or does it have a sleeve that can be replaced?
- Finally, will I need to remove the entire powerhead? If so, will I just need head gaskets or a complete powerhead gasket set?
