Spanish#007
- Jul 31, 2013
- 28
I wasn't sure if it would be big enough to provide sufficient back pressure to adjust the timing and throttle, currently the idle screw is all the way screwed in and I want to adjust everything to get it running smooth again...right now with the idle screw all the way down I'm at around 550-650 rpms needle jumps alot, with muffs on I'm close to 1400, wondering if a trashcan will work for a test tank on this size motor. See this thread for more details on the issue.
http://forums.iboats.com/johnson-evinrude-outboards/adjusting-idle-1978-evinrude-140-hp-crossflow-motor-model-14083c-620522.html#post4324263
