motor ran good 3 yrs in a row. compression at end of summer was 90 on all 4 cylinders.
so i decided to fix lower unit and trim leak which i just completed.
pulled the heads to change the gaskets and BAM starboard side headand piston is all bashed up from broken ring. cylinder walls looked good no scoring. I pulled the side plate and can see any scoring on the piston either and ring is intact from what i can see.
three other pistons have std .015 stamped on them and bad cylinder has .20 stamped into it
could this have been running like this for the last 2-3 yrs?
it ran great smooth and even idled pretty good once warmed up.
compression was even but obviously not as reliable as I thought.
i have a 140 parts motor with 90 psi all around so i pilled the heads and found the one piston and head totally wrecked.
after 33 yrs it maybe time to put the old girl away for good.
any thoughts?
any thoughts?
