mrmamiller
- Mar 7, 2011
- 167
I have a 1986 110HP Johnson crossflow V4 (bubbleback). There are thermostat/relief valve issues which need to be corrected. I read all of the forum threads pertaining to this repair job and thought I was ready. I was all set to do the job, but got cold feet after looking at the clearance required in order to get the thermostat cover/valve body in and out as one assembly. I have removed the lower cover (the one that grants access to the Tstat cover bolts from below) and after doing so, concluded that the entire thermostat cover/valve body assembly is about 1 3/4 inches thick when assembled. I did not see any way that I could get this "package" back in under the bubbleback from the rear. The only place that I thought it would be possible would be sideways out the port side. I'm not prepared to pull the power head and I really don't want to get into dropping the lower cover (the cover that mates with the engine cover assembly). From reading the forum threads, I thought the big problem would be the bolts, but it looks like they will be the easy part.
Can anyone with personal experience suggest a method of getting the thermostat cover/valve body in and out without dropping the lower cover or pulling the power head? I plan on re-installing with everything rubber banded together. Thanks for any suggestions.
