Re: What's the best way to remove the magnets from the flywheel? 1988 V6 225 Evinrude
In fairness, I didn't give anyone much time to respond to this question, but I did come up with a method that worked for me. I the hope that this will help someone else. Here is how I did it.
The magnets are very brittle, so you do not want to try to pry them off.
First I marked the location of the magnets using a small file and putting a small notch in the flywheel ring so I can put them back in the same position. Hopefully it will be close to balanced when I'm done.
I used an old wood chisel to scrap away the epoxy that oozed out between the magnets the last time they were replace. This removes any physical bond between the adjacent magnets.
I then scrapped away the epoxy on the bottom edge of the flywheel and magnet until I could see the joint where the back side of the magnet is bonded to the flywheel.
Using a brass drift and a small hammer, I very gently repeatedly tapped the end of the magnet until it began to move around the circumference of the flywheel ring. This method worked for all four magnets, and sheared the epoxy bond instead of trying to pull the bond apart.
For the best bond, be sure to thoroughly clean the mating surfaces and use acetone to remove any grease or oils from your fingerprints prior to applying the epoxy.
