KCKracker
- Jul 28, 2008
- 281
So i am swapping out VRO for a pulse pump, have not done one in a mighty few years. got the pulse pump, i can see where it mounts in the pic, straddling the vacuum outlet which i removed the plug for.
issue- underneath the mounting area about 1" is that brass connection for a hose. I am guessing this was a vacuum also for the VRO pump? if so, do i hook this up to something else, or plug it because the pulse pump will already have vacuum?
