G
Guest
Guest
I have just purchased a 1974 evinrude 9.9 for 50 bucks. It runs but is stuck in forward. I finally git the lower unit removed, it was a pain because with it being stuck in forward the shift linkage was near impossible to disconnect. Got it off and the problem is in the lower unit. I can get the linkage to move up and down but only with extreme pressure in each direction. But I can get the lower unit in forward neutral and reverse, so it works but only when basically hammering the linkage up and down. Im thinking maybe the clutch dog is acting up one way ir the other? I should be able to move the linkage up and down fairly easily correct? I drained the oil, no water or milky oil just very very black. Refilled it but to no avail. Was wondering if there are any known solutions to this problem besides taking apart the lu? I was thinking of maybe draining it and pouring some seafoam in there in hopes cleaning and freeing things up? Any help would be greatly appreciated! Its also a long shaft but don't think that makes a difference.
