BonairII
- Jun 7, 2011
- 2,727
I'm in the process of trying to sell my 14' Glasspar(w/ rotted transom) and came across a 1967 15'10" (i think) Glasspar Avalon w/80hp Johnson
Took a look at the boat today and it's solid a hell. In really nice shape. Owner says that it was made after Larson took over Glasspar and has fiberglass stringers etc. Gas tank is integrated in the front of the boat w/ fuel nozzle in the bow, which I thought was pretty cool. He only wants $300 for boat/motor and trailer....so I'm guessing that the boat alone is worth easily $300 so this seems to be a no-brainer. Not sure if the trailer is road worthy cause I really didn't take a good look at it. (Owner's wasn't home when I looked at boat).
Seller says the motor ran 2 seasons ago, but a wire got cut(see pic). He said he would explain the, as he calls it..."embarrassing" thing that cause the broken wire etc. Seller says motor was winterized by local marina mechanic every year and was well cared for. Worse case scenario, I can sell as a parts motor.
The big question I have is about the motor. Are these motors known to be reliable and relatively easy to work on? I can't find a parts schematic for it on MarineEngine, site says it's too old. Model#V4-19R Serial#J2778812
BTW: Do you think my 35hp Bigtwin would push this boat ok until I figure out the Johnson?
