Just thought I would share the photos from my teardown tonight for your entertainment and enjoyment. I'm going to bore out the bad cylinder, and rebuild the motor with new rings, seals, gaskets, carb kits, etc. I suspected the VRO as the culprit, but with just one bad cylinder and the others looking so good, I assume it was a carburetor issue causing a lean condition in that cylinder. Investigating further...
Anyway, here are some photos: http://www.facebook.com/media/set/?set=a.10150236855857539.314664.642267538&l=b0e32a0a63
