After re-reading the "How to get the best results from your question topic", I decided to resubmit on a NEW thread.
Hello All,
I'm new here on iBoats but have been scouring the available info about resealing my lower unit. I have a 1973 Sportwin 9.5 and began disassembling it last night. Everything went very well and I found no damage to any parts. The 30+ year old O-rings even look usable! Of course I have all new parts to install but I just found that amazing in itself.
This forum thread (http://forums.iboats.com/showthread.php?t=277190&pagenumber=) has been very helpful to me so far - the "spade bit" trick for removing the shift selector rod bushing worked perfectly. My only problem is that when I drove out the bushing, it kinda rolled around on my workbench and I wasn't able to see which side originally faced up/down. It has a "beveled" and a "flat" side and I'm trying to figure out which way to re-install it. It seems to make sense that the beveled side would face the fat O-ring...?
Also, any tips for removing the bearing housing? I'm going to try some Permatex gasket remover tonight but I'm thinking there must be a good way to pry it off without damaging anything? Same goes for the propshaft seal? I have a "normal" seal puller... is that needed if I have everything apart or is there some way I can just knock it off?
Any help would be very much appreciated!
Shaun
Hello All,
Shaun
