Re: Evinrude 90hp RPM Gauge Connection
I just brought a OMC control box w/o tilt and trim. There is one plug only the end with 6 wires. Pink/Blue, Yellow/red, Black/White, Yellow/Black, Purple, and Purple/White. Idon't know which is which.
well that plug goes to the connection coming from the motor!!!!
one problem WE have is we dont know what year your motor is, and we dont know what year your control is
originally you said you have 6 wires, but only listed purple, gray and black.
but now you are saying you have 6 wires that are the wires that go to the motor!!!
do you in fact ALSO have seperate purple, black and gray wires coming from your control box??
is the control a used control you bought??
they made many different controls,
what usually happens is the harness from the motor comes up and plugs into the control..old style was big rd plug to big red plug, then the control had some drop off wires OR plugs that went tovarious things...tiltn trim and gauges being some things.
the wiring after 1996 has individual plug ends of various sizes and shapes that connected to similar connectors on your post 1996 control!! ( see they have to mate!!)
you cant mix and match (unless you buy the ADAPTER harness)
got a picture of your control??
got a picture of your tach?
you really need to tell us the model number of your motor and what control you have....to help you the best
other wise, tach = grey, black and purple.... and good luck!! ha ha ha
bob
