Have a machine shop do it unless you don't mind wrecking a prop shaft.
Just read a post regarding "Quickstraight" On the boat straightening tool.
Don't know if intended for mechanically inclined diy or as a machineshop tool.
Has anyone here tried hydraulic propshaft straightening on the boat? Is it worth it? Does it work?
I remember your first thread about the problems of the motor,What motor was it? and have you looked at new or maybe a used shaft.I have had things straighted nothing on a outboard but they were never really right again.So I wouldn't have any faith in getting anything straightened that is a component Of a drive with that RPMs
