blhageme
- Feb 26, 2011
- 4
I have a 25hp Johnson model 25R70E I purchased last summer. It was at one time set up for electric start. When I purchased it, the starter was gone, but the bracket and solonoid are still there. There are two wires hanging down from under the flywheel that are terminated with plastic clip connectors (not sure what they are for). The wires to/from the solonoid had all been cut. The battery cables had all been removed. There was no push button for starting and no cut off switch (both had been removed). My plan is to buy an aftermarket starter, starter switch and a cut off switch on ebay. I just don't want to make those purchases, until I'm sure about what I'm doing. Is there anyone with a diagram of how to wire it all up, from the battery all the way to the starter, especially around the solonoid, and kindly suggest what gauge of wires I should use for each part. Thanks.
