1975 Johnson 135 HP
Been having idle and hard start issues, started late spring kept getting worst. checked compression
Cylinders 1,2,3 are 125,115,115...Cylinder #4 is 40lbs (Cold engine)
No knocking or other unuasual engine noise.
Is there away to tell if its a head gasket or the piston compression ring?
If I pull the head, what do I look for ?
