A little background first--this engine has plastic carbs and the bowls were leaking around a little metal bb in each bowl last fall. I took it to the shop to have the bowls replaced and the carbs cleaned. After I picked the boat up and put it in the water I found that it would not run off idle--apparently they didn't do the link and sync right. Took it back, they linked and sync'd the carbs, put it back in the water and it ran great. No evidence of a sneeze. However it was quite cold that day--probably 40 degrees or less.
Fast forward to the beginning of the summer. The boat is running good off idle, but will not run at idle once it comes off fast idle with sneezing itself to death. It's sneezing bad at fast idle as well. The bulb is also not staying hard, so I figure I will start by replacing the bulb. No help, still sneezing. My next step is to replace the fuel delivery hose, but I kind of doubt that is going to solve the problem. It does not look particularly bad.
I assume it must have an air leak somewhere that is causing the lean sneeze condition. If replacing the hose does not work, what is the next step? The carbs should be good. None of the fuel hoses under the hood seem bad. The cap on fuel filter is tight. I do see six small hoses running from fittings on the back of the block to each carb. From where they run I would not expect them to be vacuum, but I really don't know.
This sneezing is driving me crazy. Can anyone help?
