I'm a new poster, so please forgive whatever ignorance I display. I've done a little searching and can't find the answer so I'll post the question here: Is it possible to convert a 1973 25hp Johnson from tiller control to cable control? I want to do that so that I can set up a stick-steering system to control the boat from the front. Immediate questions are: a) does the tiller need to be removed? b) does the bottom portion of the cowling need to be replaced with something that will allow cable access?, and c) any suggestions on a particular conversion kit? Thanks in advance for any responses, dlg
