Re: 1978 jonhson 70 hp idle adjustment??
The idle screw is the lower of the two screws located on the levers which drive the carb and ignition timing adavnce . The top screw is the throtlle stop screw, just make sure it is not a problem with the control links when in neutral the lever should sit against the lower idle screw , if it not it is most likely a problem with the levers somewhere .
Rgds
bob
