Welcome Guest - Sign Up today
No announcement yet.
Will a cotter pin work as a shear pin?
  • Will a cotter pin work as a shear pin?
    I sheared a pin today when I bumped a stump with my lil 6hp Johnson. Was ust wondering if I could use a cotter pin as a substitute for a day or two till I get some new ones....Or anthing else that might work. Thanks for any advice...Fishermanms
    Re: Will a cotter pin work as a shear pin?
    Might work for a short time. Anything is worth a try in a pinch. I have even used a nail when I could not find anything else. Wount take a lot of torque, but goy me home.
    • #3
      I wouldn't recommend it, especially if your going to use it in the same water. You may hit that stump again or another one if not fimiliar with the waters, and screw something else up, or break something and be stranded.
      • #4
        Yes, if you take it real easy. I have a friend who sheared a pin and only had match sticks to replace it with. He made it back to the dock, it just took a while!
        Old geezer who never worked a day as a professional in the marine industry but has been fooling with outboard motors for 60+ years!
        • #5
          Yea... Whatever I do Ill take extra precautions..I could fabricate one if I new what they are made of. I thought about making one out of brass. I checked the local auto zone and O'reallys but they did not even know what they were...Can you believe that!
          • #6
            just make sure it is temporary. you don't want it to rust into place, and not be able to get it out.
            FLORIDA GATORS
            TEBOW Country
            Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
            That is what these forums are for. Post your questions, in the appropriate Forum.
            • #7
              cotter pins are made from brass if you have some the same diameter you can make them yourself been doing it for years with no problem.
              • #8
                Yeah it might get you back to the dock...cotter pin. Buy some brass rod the right diameter at the local big box store and cut your own.
                • #9
                  What year is your 6hp? Many of them use a part number 307949 DRIVE pin. It is 3/16" diameter by 1 3/8" long and is made of Stainless Steel. It is called a drive pin because it is not supposed to shear. The rubber hub in the propeller takes care of the impact of stumps and bumps.
                  • #10
                    edit
                    • #11
                      Buy a small package package of bronze brazing (welding) rods of the proper diameter. You can cut as many as you want for a couple of bucks.
                      • #12
                        I missed the post that asked where your spare (reserve) pin was.
                        Guess you'll have one next time.
                        Anything will work,but get the real thing.
                        DHP
                        • #13
                          Originally posted by ezeke View Post
                          I will personally guarantee that a 307949 is a shear pin. It is precisely what I use in all six of my 9.5HP motors, and the kids manage to shear at least one a year. They usually break them by trying to shift at too high RPM.
                          I have a '69 Johnson 9.5 - is that the shear pin for my motor as well? I just got the motor, and after reading this, I think I should probably pick up a spare.
                          EDIT: Nevermind, I found the BRP Part Catalog and verified it's the same number. Thanks!!
                          • #14
                            Please do not "make" substitute shear pins. The OEM pin is made of an alloy selected to protect your prop and geartrain. The real thing is too easy to find and too inexpensive to mess about with substitutes that may result in a destroyed geartrain.
                            1. Always carry at least one spare. Many engines had a clip inside the cowling specifically for carrying a spare shear pin.
                            2. In an emergency you can reuse the sheared pin. Here's how.
                            When the pin shears it breaks into three pieces; one long and two short. The long one is inside the propshaft. Switch places between the long one and one of the short ones. That will give you half a shear pin which should get you back to the dock. Did that a few times when I had already used the spare in rocky, unfamiliar waters.
                            sigpic
                            • #15
                              I did not intend to imply that the drive pin won't break if you really clobber it. It is a drive pin and is so called in the book. Reminds me of the time I sold a guy a new 2hp. He asked about the shear pin and I told him there was a spare in the owner's manual kit. But also told him it is a drive pin not intended to break unless really abused. Well a few weks later he was back and upset because I told him that he "didn't need a spare". (That's not what I said at all). Seems he took the motor up north somewhere and put it on a canoe and went way out in the wilderness and shot a moose. Loaded the moose in the canoe and headed for home, only to hit a rock and broke the drive pin. Seems he didn't take the spare along because I said he "didn't need it". How 'ya going to fight stupidity?
