dingbat
- Nov 20, 2001
- 15,501
Getting a lot more water than normal coming from the joint between the exhaust housing and the lower unit this year.
Came home yesterday to find staining from the bottom of motor mount cover after a 30+ mile run. Cant swear to it but motor sounds louder as well.
I suspect the gasket(s) on the exhaust housing are shot or out of alignment. Put a new gasket in when we changed the water pump because I had it here at the house. Guess I should have left "as is" or replaced both.
Plausible?
Plausible?
