aburke120
- Jun 27, 2011
- 183
1979 Johnson 115 running real good on a portable tank, switched it over to the
inboard tank that I had put some mixed gas in, and the motor fell on it's face.
Hooked up the portable and it came back to life. So I found another tank hose
and primer bulb, stuck it into the main tank and drained out almost 4 gallons of
stinky nasty looking gas. Hopfully I got most of whatever was in the tank. Going
to put something, Heet, seafoam, or something else into the tank then put a couple of gallons
of mix in, and see if it will run.
