GatorRx
- May 21, 2020
- 4
First post, here we go.
I'm having a heck of a time trying to get this engine running properly. It idles ok in the water and out of water on muffs. When I put it into gear and try to accelerate it wants to bog down and die. By fiddling with the throttle and very slowly increasing it I can get it past the point where it wants to die and get up to full throttle.
The issue I have found is that the engine will not idle on the top cylinder unless I am squirting gas into the top carb. It will idle on the bottom cylinder (roughly) without squirting gas into the carb. I can get it to run on the top cylinder if i get the revs up a bit though. To try and figure this out I bought a service manual and have looked on this and other forums, here are the steps I have tried so far in no particular order.
-Cleaned and rebuilt both carbs (cleaned top carb twice)
-New spark plugs
-Checked spark (good on top and bottom)
-Checked compression good (120psi on top and bottom)
-Replaced fuel pump
-Decarbed engine with Seafoam
-Checked timing
-Verified that throttle butterflies are opening and closing correctly
-Applied some heavy grease on the outside of top carb body at the point where throttle linkage enters (thinking possible air leak)
Is the top carb the culprit and I need to replace it? Not sure what I should look at and do next.
-New spark plugs
-Replaced fuel pump
-Checked timing
